Hello all,
Just recently I rebuilt the passenger side hub, replacing the bearings as they were making way too much noise and there was a lot of play. Prior to this work I had no issues with steering or alignment.
Once I did this, ensuring that everything went back together the way it came apart, the car pulls severely to the right. I double checked everything after a day or so but all seemed to be as it should.
I noticed that there was play in the drivers side balljoint so I replaced both lower control arms with brand new Moog ones. I guessed wrong, the car still pulls to the right.
I have a theory about what has happened. When I removed the steering knuckle to rebuild it I only jacked up that side and had it up on a jack stand. My theory is that while it was sitting up on the stand the sway bar and everything attached to it slid in its mounts towards the passenger side. Another symptom is that the driver's side tire is wearing very quickly on the outer couple of inches of tread.
Let me know if you have any ideas as to what I may have messed up. I'm going to jack the front of the car up and loosen the sway bar mounting bolts and shock mount bolts to see if things "spring" back into proper position. I'm also going to check the steering rack. I should get to that later tonight or sometime tomorrow and will report back.
Once that's done I'm going to replace the tie rod ends, inner and outer, and then find a reputable alignment shop to put things as they should.
Cheers,
Cheers,
