So I needed to change the valve cover gasket on my wifes '91 'stiva EFI and I decided to do a tune up at the same time because it had a light miss below about 2500rpm. So I just got done with all that, new plugs/wire/cap/rotor, and good stuff with brass contacts and NGK Vpower plugs. Now it's missing like crazy, sits there and sputters like a two stroke, but still only below about 2500rpm. Once I get past that, it seems to pull harder than it did before the tune up.
I did all the usuals like pushing harder on all the connections and unplugging, replugging. Checked the connection to the VAF just to make sure I hadn't bumped it out or something. I finished right as night fell and no garage, so this will have to wait until the morning, it just seems really odd do me.
The plugs I pulled out were old and worn, but had good color. The cap and rotor both had quite a bit of corrosion on them so I figured changing them would do the trick.
Any ideas you may have would be great!
