1993 Festiva. Starts fine and runs pretty good when its cold, when it starts to warm up it begins to idle a little slower, and when you rev it up and let the gas off it will stall, makes it hard to drive, and noticed some black smoke. Any idea what I should check? Thank you very much.
Wont stay running, Any help appreciated
coolant temp sensor, o2 sensor, double check timing and if it's advancing. Sounds like once it wants to go into closed loop a sensor is giving it bad info. It might also have a vacuum leak. Again once it wants to go into full computer control it cant compensate for extra air it doesn't know about.1993 GL 5 speed
Black smoke usually means that you're getting to much fuel or it's not being burned. Start with ignition first.Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
Plugs, rotor, cap, wires, ignition timing. the list goes on. When's the last time the car had a general tune up?
1989 L - 247K miles Slick
if replacing the o2 sensor, use Denso ONLY.Trees aren't kind to me...
don't replace anything until you have verified it is a bad part. O2 should show a varing voltage between 0 - 1V if stuck @ ~1V then look at overfuel or under air, if stuck @ ~.1V then look for false air. In either case try to force the opposite condition (lean force rich ect), if floating in mid voltage then that ain't it.
my $.02
at least you'll actually have a good running car when you're done.... FESTIVA MADNESS is a nontreatable disease that affects all Festiva owners (At least that I've met)Andrew Walker
Current Daily Driver:
89 Nissan D21 SE V6 5 speed 4x4
Projects in the works:
84 Mercedes Benz 300D(T)(Baby) currently awaiting transmission transplant/ full on restoration
Not a lot to these cars. If you plan on keeping it for a long time the most you'll spend on all of those items is $100 and youll be good for a long long while and have peace of mind. All of it transfers over to a b6 too
1993 GL 5 speed
Another thing which can act up when the engine gets warm is a failing ignition control module in the distributor. It can be taken out and taken to some auto parts stores for free testing. If replacing bed the new module in dielectric heat transfer paste from an electonics store. It's the stuff they put under CPU's in computers. Protects the module from heat and eletricity. Also, if replacing shop around becuse they are made by one company but sold retail by many with different markups.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
