Having problems with an 89 carbed. Haynes manual shows "AP" switch in the engine electrical schematic. It's tied in to the coil I believe. Buddy's car quit stone dead. Diagnostics show that this switch is not fully operating right. Already changed the ignition module. That made the engine run, but only for a few minutes. Coil has been checked too. Searching for AP switch brings up all post with switch in it(500). Anyone have any ideas?
Anyone know what the AP switch does?
88L 328,000 winter daily driver
93L 167,000 summer daily driver (AC)
90LX 374,000 swap candidate
88LX black- parts
89LX burgundy-parts
91L red-parts
Someday my ship will come in. With my luck, I'll be at the airport. (aviation machinist)Tags: None
I think the AP means atmospheric pressure switch. It's the 3rd wire going to the distributor. You can just unplug it. I don't think it is going to be the problem. It just makes the timing advance or retard or something like that when you are at high altitude. Mine's been unhooked for years. Check for 12 volts at side of coil with black/white wire. If low could be ignition switch. New Ignition module could be bad too. Check for spark at plug wires. could be something fuel related.Last edited by zoe60; 03-03-2011, 08:35 PM.
Originally posted by kartracer46 View PostDoes it crank and just not getting spark?
OK-Bad module. Problem solved.
Leave car running, wash hands for supper. Engine dies.
Now it has a very weak spark and will not crank.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
Originally posted by zoe60 View PostI think the AP means atmospheric pressure switch. It's the 3rd wire going to the distributor. You can just unplug it. I don't think it is going to be the problem. It just makes the timing advance or retard or something like that when you are at high altitude. Mine's been unhooked for years. Check for 12 volts at side of coil with black/white wire. If low could be ignition switch. New Ignition module could be bad too. Check for spark at plug wires. could be something fuel related.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
Check the coil for 12V, If it's not there replace the main fuse. Then if you have 12V check to be sure your ignition switch wire at the plug to see if there is 12V coming in, Then you can check the connection at the leaving with the key held in the start position to see if the switch contact is allowing current to pass to the starter. You may just have a sticky or failing ignition switch.91 Festiva GL "Scrat"
82 Honda Goldwing GL1100i
85 BMW 535is "Brunhild"
fixed
Changed the disty again and left off the wire for the tach at the coil. Runs fine now. Seems to be a ground problem either in the wiring or in the ecu. This mostly means that the shift light doesn't work now, no big deal.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
