What is the best way to mount your b6t to the engine stand and what size bolts do you use to keep it on there. I went out to home depot and got some 4pm bolts wit nuts but they were to fat to go thru the holes. Any help would be appreciated.
Engine stand issues
Engine stand issues
Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
http://www.facebook.com/#!/profile.p...00000110128487Tags: None
I just used bolts that were small enough to go thru the holes and put a nut on them. It's hard to find metric bolts that are very long without paying $10 per bolt.-Greg
Redneck Engineer
FOTY - '09
ThanksFrankie
If you can't find long metric bolts, look for metric threaded rod. That's what I used when I needed a new bolt to hold the air cleaner on a carbed B3.You gonna race that thing?
Nice thanks guysFrankie
