what oil pump do i need!!??
  • what oil pump do i need!!??
    i ordered an oil pump off ebay and its the large crank for the b6t, my engine is the small crank!! what year and model had the small crank? i have no clue what my engine came out of :tard:
    88 festiva lx, 2.3 turbo rwd swap in progress
    1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
    R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
    00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
    03' gt, full termi swap 700+ whp build
    sponsered by,
    pam pam's junk, dayton OR.
    Bob's ok tires, salem OR.
    Clausen Truckin', keizer OR.
    im pretty sure a 1988 mazda 323 gtx was a small nose
      Well my pump has "b660" casted on it and the pump I bought has "b6S8" on it. I found one on ebay that is oem from mazda in the box that has the cast #b660 and has 6 bolts on the rear of the pump like mine.
      The big nose has 7 bolts on the rear. So I'm waiting to see if I can get a refund for the one I bought bc its a 323 gt that has the small crank and he had it listed wrong bc he sent a big crank pump.
      sponsered by,
        why are you replaceing the pump? did it fail? to be honest if you plan on building a motor down the road i would look for the big nose 1.6 crank and just swap it in, the short nose are known to fail. put a wanted post on turbomiata.net or miata.net, they can be had for a 100 or less, most of those guys give 1.6 stuff away due to they rather swap in a 1.8
          So is the 91 capri a big nose crank? And has the same main cap sizes and rod sizes correct? There is one at my local jy I can go grab for cheap if that's the case.
          sponsered by,
            No the pump didn't fail, I'm replacing every componet. The engine sat for god knows how long. So I would like to just have the assurance of all new parts.
            sponsered by,
              http://323gtx.homestead.com/engine.html
              http://miata.net/garage/crankshaft.html
                Thanks for the info! I will have to see if the capri is a late 91 or early 91 I guess bc there anr NO miatas in my area.
                sponsered by,
                  Looks like the kia sephia and some protoges have the long nose crank as well.
                  sponsered by,
                    After reading the miata info on the above link. I have the fig#3 crank. (Small diamater with long keyway) this crank was a revision I guess and doubled the keyway area. I don't need a big crank to run big hp.
                    sponsered by,
