motorized seatbelt help
  • motorized seatbelt help
    My place is not the FMS complaint department. I don't allow anti-FMS posts here. The owner is a friend of mine, and he out ranks any noob here.. don't like it? Don't let the door hit ya on the way out.. Your complaint post will be deleted and so will the others..
    DJ Hayek
    Have you tried to spray some lube in all the track area from where the buckle starts and stops , that has helped mine when it started getting real slow and almost stopping.
    HD2500 Duramax Chevy
    Z28 LS1 power 500 +
      DJ Hayek
        The switch is in each door latch, and the control is under the driver's seat. When mine started sticking I replaced the door latch.. Check to see if the connection is good first if so change the door latch. The latch is way cheaper than the module if I'm wrong.
          DJ Hayek
            If you need the module FMS usually sells the module on Ebay for $9.99 $8 shipping. You could probably call them and order it also. There number is (410) 381-4660
            93 GL modyfied!!!
            :fish:
              DJ Hayek
