Hey, Im new to this forum.
I have an 89 Ford festiva, manual trans, 2BBL Carb.
Im trying to get it all fixed up for inspection right now.
The high beams dont work right now.
Low beams do work.
If I push the switch foward to where it would engage into the high beam switch the headlights just go out....low beams are off(normal), and high beams dont come on.
If I hold the switch back(where the hi beams come on as long as you hold it back) they work just fine, but obviously going back off as soon as you let go.
I havent done any diagnosis yet....but I wanted to see if anyone else has had this same problem or have any ideas of what I should do to fix it.
Thanks a lot!
Low beams do work.
Thanks a lot!
