ok so ive got the engine in and it will run on starting fluid but the efi is not working. I need help figuring out whats going on. the escort gt distributer has for wires but with only 3 connected it runs, where does the 4th go? do i need it? how do i get the efi to work?
escort gt swapped in got fire but no efi help!!
in the festiva manual it says that the injector wires are green/y and green/blk but they do nothing at this point so im trying to figure out why not. how do i get power to them? is it from the dist. and if so couldnt i jump from the dist to the injectors?
one has constant power the other is a switched ground via the ECU. there's a fuse for that circuit (EGI).Trees aren't kind to me...
