I need help with these lamps!!!!
there is a Phillips head screw at the top right side of your headlight.
remove the screw, which will release the little metal arm that holds the top of your side marker light.(almost in the middle of your 2ND pic, closest to the fender)
then you have to VERY CAREFULLY take a flat head screwdriver or a small pry bar and put it down into the little opening, from the top, to the right of the headlight(to the right of where you took that screw out)and pry out the bottom right of the side marker light. until it pops out.
