Originally posted by FestYboy
I drove the car 1000mi to Nova Scotia, getting ~50mpg.
One very wet day, I went out to the car and I noticed it running very rough. The only way it would move is if my foot is barely on the pedal, otherwise it bogs down. If I rev in neutral, it acts hesitant, randomly revving up ~500rpm. It never went above ~2500rpm. It stalls pretty randomly. If I ease it down to ~1000rpm, and then let the clutch out it usually -won't- stall. If I just let the clutch out at high rpm it usually -will- stall.
First mechanic said that it needed new piston rings because compression was lost in two cylinders.
Second mechanic said the compression was fine.
Once the weather dried up, the car was still running very rough. However, the car would rev all the way up just fine. It no longer bogged down when I floored it, allowing me to drive it home. Driving it home it got me ~30mpg.
Unplugging the VAF allows the car to idle without running rough at 1000rpm. When it is revved with the VAF unplugged, it dies. (I'm under the impression that this is normal.)
Sorry it's quite long, just trying to bring some clarity.
