The bottom of my mirrors, just above the bottom lip, have been damaged due to the sun and look foggy/cloudy no matter how much Windex you use on it. I'm sure many other owners have the same problem.
Question: do the replacement mirrors/glass I see on e-Bay for Festivas simply glue in externally or do they require you to take off the rubber mounting boot and go in from the side of the mirror housing?
At first I thought you simply broke out the old mirror and glued in the replacement without removing the rubber boot, but in looking at the mirror assembly more closely it appears that the factory glass actually extends beyond the edge of the plastic mirror housing lip. If so, do you just brute force the rubber boot off? If you take the boot off to get the glass in, are they prone to rip?
