My problem is different and only when engine is cold (just after starting). No coughing. Just a subtle hesitation which I never experienced in the past when starting off in either first or second gear. And only when cold. Once engine warms up, it drives fine. I also may remove and clean the engine coolant temperature sensor. Maybe that's not operating right and not sending enough gas when it's a cold condition. I am also going to test the resistance of each spark plug wire and clean the distributor cap and rotor.
This is my 100th Post!!! This is a great forum and appreciate every ones help! THANK YOU !!!!
