I really love festivas! Ive been looking for a low cost manual trans festiva for quite some time now. I have found an auto festiva, and it doesnt shift into reverse or low (when it is shifted into low, but uses first as usual in drive). It is priced at 400$ and im sure i could get them down to 300. Do you think i will have further problems with the transmission? It is a small car so i can push it in reverse, and i dont mind. Let me know what oyu think rubbereyes3@hotmail.com
Advice on buying festiva.
Thank you! What do you think a used transmission should cost (so i know what to look for when calling around)? Also I was wondering if you had any estimates on how long the trans should last. Is it an immediate threat, or something that will gradually get worse?
I cant wait to get back into the "Festiva Club"
Ive missed my festy dearly, and now Im emotionally ready to fill the void it has left in my heart.Froggy in the meadow, under the log. BIG JILM!
Re: ..
First thing to do is find a junker Festiva with a 5 speed.Originally posted by DyflonThank you! What do you think a used transmission should cost (so i know what to look for when calling around)? Also I was wondering if you had any estimates on how long the trans should last. Is it an immediate threat, or something that will gradually get worse?
Take off the shift stick, shifter linkage, shift boot, clutch and brake pedals, clutch cable, transmission, CV axles (difference between auto and manual CVs), clutch, nuts & bolts and anything else you think might be related to the transmission.
Pull off the automatic transmission and all its associated parts, and swap them for the manual. Replace the clutch while you're at it, since they're only $100 new.
Transmissions can run anywhere from $50-300 depending on where you look. Believe me, it pays to shop around!
Regards,
TimWhite '89L auto - Sold!
Silver '06 Rav4, 95k!
