My 1994 5 spd aspire (127000 miles) came with gear oil in the tranny. It was shifting great. I drained that and refilled with dex/merc atf per the Hyanes manual, drove it for a couple hundred miles and changed it again. The atf that came out was still red but full of metallic particles. I refilled it and drove it a couple thousand miles. Now it is shifting hard (particularly first to second gear) so I changed the fluid again the other night. The fluid that came out is filled with metallic particles again. Fluid level is correct per speedo cable dipstick.
Is it normal to have lots of metal particles in your atf? I know when I change the fluid in automatics it looks new still, but those have a trans fluid filter. Is my tranny eating itself up? Can I do anything to stop it? Is this just the syncros going bad? You can buy a new bearing and syncro rebuild kit for this tranny for $150. Should I put one of these in before it eats the gears up? Thanks for any help or similar experiences.
