Wanted to post that the radiator fan switch and coolant temp gauge sensor from Advanced don't play in my 90L 5 spd w/tach cluster.
Picture shows difference. The Advance part for the fan switch looks like the OEM temp gauge sensor but it isn't.
The Advance fan switch operates just like the OEM in that it is a temperature sensitive on-off switch that opens when coolant temp reaches 207°. The coolant temp gauge varies its resistance with change in coolant temp. Advance P/Ns: Radiator fan switch = TFS525. Coolant temp gauge sensor = W5000.
Other than JY, does anyone have ideas? Did all years of Festivas have same size parts & threads with same connector types?
