Rack and Pinion Lube?
  • Rack and Pinion Lube?
    Both the boots on my rack are torn. When I go to replace them, is there anything I need to do to the rack to lube it? Add some gear lube, grease a fitting, anything?
    89 L
    just clean VERY well
    and lube it with a general ball joint grease( or a synthetic)
      I used good old moly grease on my dad's rack and pinion. Seemed to work pretty good, as far as holding up time will tell.
      91 rusty Festiva 260k
