95 Aspire. OBD-I.
On this last tank of gas, my mileage dropped significantly. I have recently done a complete tuneup--air filter, NGK plugs and wires, good quality cap and rotor. Car runs great, but mileage has dropped. At the same time I filled up and noticed the mileage drop, I also stuck a bottle of Sea Foam in the gas BTW.
I'm thinking the O2 sensor. So I checked the voltage readings with my digital multimeter, and it read as expected--up to a point. When I started it cold, the reading was below .1v and gradually climbed as the motor got hotter. The max it read was .68v, but the Haynes manual sez the range should be from .1v - .9v.
So is my O2 sensor going out? Has anyone confirmed with a new sensor when they installed it that the proper range is indeed .1 - .9v?
