Originally posted by getnpsi
Escort motor for my festy
If I remember correctly the 1.9 has about 88 hp and the GT 1.8 has about 127 hp.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Im glad I asked before I got this car I was thinking of the 1.8 when I found this, that would have been a bad mistake. What does the 1.8 come in I need a motor my 1.3 is starting to get hurt and Im looking for a motor to build while I drive the car, I should be asking what motor should I get Im not looking for a hot rod I drive 100 miles a day and need the fuel mileage but would like more power so I can run the A/C without using an entire tank of gas. And Thank you guys for letting my know I was about to mess up big.
mazda 323 1.6 is exactly what you need. SOHC, direct swap more power good fuel economy and takes 0 effort to swap.Originally posted by Tommy View PostIm glad I asked before I got this car I was thinking of the 1.8 when I found this, that would have been a bad mistake. What does the 1.8 come in I need a motor my 1.3 is starting to get hurt and Im looking for a motor to build while I drive the car, I should be asking what motor should I get Im not looking for a hot rod I drive 100 miles a day and need the fuel mileage but would like more power so I can run the A/C without using an entire tank of gas. And Thank you guys for letting my know I was about to mess up big.
1.9 is just not a set it and forget it type of engine. Once the valve dropping issue is addressed with a new valve job it's just as potent as many older tech engines. I could be wrong but i think the 1.9 would be the budget swap into a first gen ford fiesta, that thing would move with a t-25 and megasquirt lol.
OP: if you want to keep a/c the 1.6 is the engine you want unless you want to do a little trial and error notching the frame. The longer blocks will require this. eurostiva has a 1.8 engine in his car with a/c.1993 GL 5 speed
1988ish engine, but 1992ish ECU.
1993 GL 5 speed
A CVH swap is theoretically plausible into a Festiva. A few of those escorts used an F tranny. 323 Diff swap into a trans with the CVH Bell, 86-89 323 CV's and you're good to go. There's just not much point; if you're going to do a diff swap, custom mounts, and a massive wiring overhaul just to make an impractical engine swap work why not do a K engine?
It's like swapping a GM 2.8 into, well, anything. The potential for power is there if you have enough cash, but otherwise it's an unreliable gutless fuel pig in comparison to the easier swaps.
They where def pieces of Junk. You could take three good 1.9's and use them to make one good junk 1.9 motor. How Ford ever made them is behond me. I guess its a good thing that they let the Asian's build some of their 4 cyl's. The Z tech's arent bad though I had a 02 ZX3 that you couldnt blow up (I tried). But everything else failed @ 60K. And I mean everything. Pissed me off so bad I had to buy a 06 civic.Originally posted by stefan View Post
Those 1.9s are prolly the worst motor ever built lolSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Those 1.9s are prolly the worst motor ever built lolThis is ridiculous. Tell that to my buddy driving his with 275k original miles. The motor is very durable and efficient.Originally posted by nitrofarm View PostThey where def pieces of Junk.
This is not a motor you want to put in your festiva but it is a great tough motor.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
Mechanics only see the worst of everything, kinda like gynecologists? There are scores of ugly teal and/or forest green 1997ish escort wagons still out there on the road going strong where I live. SE model focus has the 2.0L version of the 1.9 and plenty of those in the 150k range or more keeping someone happy.1993 GL 5 speed
