Thanks!
Anybody know where the air intake temperature sensor is?
Why do you ask?'93 Blue 5spd 230K(down for clutch and overall maintanence)
I get a code of one long flash, then one long and seven short flashes (O2 sensor).Originally posted by Pu241 View PostWhy do you ask?
I think the one long flash is a code 10 (air temp sensor)?
Not too sure though but the spring in my airflow meter that closes the flap is giving up the ghost.... I disassembled and cleaned- lubricated- removed the lubrication which seemed to get it fully closing but I'm not too sure it is fully closing EVERY time the throttle closes...
So if I have to replace it to solve 2 issues it will be easier to justify the cost!1990 Fistiva L PLUS 41.7mpg
2003 Mitsu Evo Bolt-ons, cams, IX turbo...
tuned on 93. Real slow car...
2002 1 ton 4wd 4 door Duramax/ Allison DUALLY... 14.3@92mph.... huh.
