Seems pretty clear, but thought I'd post to see if I am missing something..
For the first time in the 2 years I've been driving my Festiva, it wouldn't start. I have been meaning to replace my ignition wires, so I figured that might be the culprit since it is a very damp and cold morning. I sprayed the wires with silicone wire dryer, but still no start...
Next I checked to see if I had power to the coil. YES.
Then I figured I'd check for spark, so I had my wife get in the car and turn it over, I saw spark jumping between the power input of the coil, and the coil wire outlet.
Bad coil right????
I went in my stash, and picked out a decent looking coil. I installed that, and ALSO saw the light show of sparks. Although It did start... It will idle, but if you give it gas, it misses bad, and you see the spark jump at the coil...
I assume a new coil would be the fix???
Any thoughts?
Oh..btw this is a 1993 EFI car
Thanks!
Bad coil right????
Any thoughts?
Thanks!
