Need to install a new head gasket on my B6 with rear turbo. I talked to Greg first, and have read my 91 Festy shop manual and the Haynes for Festivas too.
Greg said he wasn't sure if the B3 or B6 head bolts were torque-to-yield (meaning one-time use) or could be re-used. The manuals didn't mention this either way, and I expect they would if it were an issue. So I am just checking here in case I should be buying new head bolts.
Also--does anyone know the torque specs for the B6 head bolts? I expect they are the same as the B3, which are 56 - 60 ft/lbs according to both manuals, but don't know for sure.
Thanks!
Thanks!
Good luck!
