I just swapped a complete fuel injection setup into my 89 L festiva. got the car to start but it wont idle and I also have no running lights. Any suggestions?
Cant get my running lights to work
If you swapped in the Fi harness into the carb then you had to swap in the lighting part of the harness aswell. Double check the connectors, bulbs,fuses and grounds. Possibility that you might have a bad connection somewhere.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
I swapped in the entire harness from front to rear, There is an extra plug at the headlight switch I was told needs to be spliced together? all grounds fuses and bulbs are good.93 Ford Festiva L new project-dd big plans
89 Ford Festiva L (snoopy) long gone
2002 Chevy Venture warner bros edition (wife's car, child hauler)
