I sprayed starting fluid around the throttle body, pcv, and air tube on cream puff. Can't locate the cause of a stumble. It REALLY feels like a vacuum leak. Under mild acceleration it loses power for a moment then recovers. Under heavy acceleration it hits a wall and then recovers. It also has a weird idle. It will fall to 500 rpms and stay and sometimes it will go to 1200 and stay. It is also a little rough. You can feel it in the pedals. As oppoesed to a perfectly smooth festy idle.
When I got it it had that rough idle and varied by 200 rpms. But it had no stumble.
What I've done since then....
Plugs, wires, distributor cap, rotor button, fuel filter, air filter.
Installed ac.
Installed ac.
