Horn relay missing??
  • Horn relay missing??
    New festy= :p Horn doesn't work, have not jumper wired it yet, went under the dash to see if I could see the relay, and this is what I see, 3 empty brackets plus one hanging wire/plug plus one relay labeled as key buzzer or something with an empty socket. pics below, whats missing?
    1st pic is brackets and relay with empty socket
    2nd pic is hanging plug
    Thanks
    Also I have some extra bits from the buy but I don't know what these missing bits look like, so if someone has pics under the dash that'd be great
    Owner of:
    1991 Red Festiva L, 5 speed (Swagger Wagon)
    In progress:
    BP+G25MR swap, Kia rio axles hopefully.
    year of car please...
      The horn relay is found in Escorts and Mazdas of the same vintage. It's a blue box under the dash that has a four wire plug.
      Sometimes the horn buttons get stuck. Even if the horn doesn't work, the relay will use power to hold the coil closed and will slowly kill the battery. They might have removed the relay to relieve this problem.
      That's what I think happened on my car at least, haha. I ended up replacing the horn with one from a grand marquis and the relay from a Protege.
      -Zack
        Woops, sorry about that, it's a 91 L, So I need a horn relay, I'm assuming the hanging plug goes to it, and what should plug into the other black box under there.
        Owner of:
        In progress:
          Got whole bag of them, I can post a picture so you can see what they look like.
          91 Festiva GL "Scrat"
          82 Honda Goldwing GL1100i
          85 BMW 535is "Brunhild"
            The plug goes to the key buzzer, which is the black box. Most people unplug them because it buzzes when the key is in the ignition and is annoying.
            '90 LX
              Alright, that'd be great if you could post a pic, couldn't get my fat head under to see what I was plugging in and I didn't want to break anything. Also, what do the wires that plug into the horn relay look like?
              Thanks
              Owner of:
              In progress:
                Okay, I believe the box in the pic with 4 wires that are mostly green is the horn relay, it clicks with horn button, It is grey and says GE-70 on the side. The hanging plug has 6 or 7 wires, lots of red. Does not plug into relay labeled key buzzer. Someone please put up a pic of a complete under dash relay setup, the manuals I have are black and white and tiny pics. Thanks so much
                Also, learning stick is more of a handful than I thought...
                Owner of:
                In progress:
                  I apologize for sounding short, it's been a long week.
                  Owner of:
                  In progress:
                    Here is a pic. You aren't missing anything.
                    The gray relay with the four wires is the horn relay. And the plug that is hanging down with the seven wires does go to the key buzzer it only plugs in one way and that might be the reason you can't get it to plug in but I can assure you that it does go to the key buzzer. Hope that helps.
                    '90 LX
                      So what's the black one that says H300? And looks just like the ge-70?
                      Sent from my PC36100 using Tapatalk
                      First time owner
                      89 L carb'd - white / still needs work
                      Bought for mpg and only paid $250
                        Thanks a bunch, I think my buzzer relay is missing pins, oh darn, I'll get the horn unbolted this weekend to try and test it to see whether it's the relay or the horn. Is it just the one bolt holding the horn on?
                        Owner of:
                        In progress:
                          I check the ground before doing anything.
