I know the safest way to break the bead on your tire to change it is to use the equipment at the tire store that's made for the purpose.
If you're changing tires at home, here's a fairly safe and quick
method that I use.
What you need:
A jack
A small prybar
A few small pieces of board (Oak flooring boards used in photos).
Jack up your festiva in front an remove the wheel.
Place the wheel under the wheel hub.
Place the curved end of the pry bar under the hub in the low
point between two lug lobes.
The pointed end needs to be right on the bead at the edge of the wheel.
Place board across the tire to raise the prybar so that the prybar point is angled slightly toward the wheel at the bead.
Gently lower the car until the bead breaks.
Turn the tire over and repeat for the other side.
If you want to save the old tires, be sure to dull the sharp pry bar edges.
Works great for me.
![](https://picasaweb.google.com/105052195308338442517/BreakingTireBead?authkey=Gv1sRgCIGC_qfjyNasDw#5605606487536570386)
If anyone else has a better way, I'd like to hear about it.
![](https://picasaweb.google.com/lh/photo/pVZtI3dfXf7pwW9OSPwLqF5W67nYA_mN58fx1Hs2NFc?feat=directlink)
![](https://picasaweb.google.com/lh/photo/8VMPvfX4G5yKSKLmnUFF-l5W67nYA_mN58fx1Hs2NFc?feat=directlink)
Here are all Pictures.
method that I use.
What you need:
A jack
A small prybar
Works great for me.
