I'm trying to get my oil pan off the engine block from under the car. It's a B6, so there is the main bearing support plate to keep away from. I only need to get the pan off.
I'm cutting around it now with a razor knife. This might be the hardest part of replacing my oil pump! It was hard enough when the engine was on a stand. Now everything's in the way. I did take the grille off, which helps a bit.
Anyone got any tricks up their sleeves?
A magic wand, perhaps?
Thanks,
Karl
Thanks,
Karl
