I was about to remove the oil pickup tube and reached for my 10mm socket and wrench.
Didn't need it! Both bolts were LOOSE!
Here's two pics to compare. The first one I'm pushing the pickup gasket surfaces together, like they should be:
In this pic I let go:
Depending on picture resolution, you should be able to see the small gap. It was enough to prevent suction from the sump, where the oil was.
This HAS to be the problem, and explains the slow progress of the "disease" as the seal loosened and I lost all suction and thus, oil pickup.
Here are my thoughts:
I'll take the pickup off, clean it up along with the mounting holes, add mild thread locker to the two 10mm bolts, and this time, MAKE SURE I TORQUE IT RIGHT!
I could'a sworn I torqued it properly the first time, but maybe not. Maybe that was the first time, before I opened the pan up to get the seal out I had left inside.
Sound good? I don't think I need to install the new oil pump, nice as it looks. I didn't break the old one's seal yet.
Reinstall pickup tube, clean pan gasket surfaces, and reinstall oil pan.
If anyone knows different, lemme know. I'll be cleaning stuff up.
Thanks,
Karl
Thanks,
Karl
