I know there are numerous threads around but not are all clear just how they got them fitted. Everything is done bar wheels and brake lines, I just can't get my head around how to fit the aspire bar. Upside down / right way up put aside, the crossmember is the problem. I don't have a welder so the notch/cut is out and trust me, nobody around here will mess with anything structural so I couldn't pay someone to do it if I wanted to. Did most of you notch the crossmember and fit it that way? Without a welder I don't like the sound of it.
So that leaves dropping the front of the crossmember a few inches and lifting it over (right way/wrong way, both should work) but that leaves 2 problems - radiator hose and probably need to wrap the section of the bar over the crossmember with some kind of rubber sleeve to prevent damage to tranny in times of stress.
So I've kind of given up and feel pretty deflated after being built up with excitement for so long about completing this job. Tomorrow I'm likely to put the original festy bar on, at least I have new poly bushings for the control arms which should stiffen things up a bit right?
Does anyone have any input?
