I'm swapping it tomorrow. Looked for it in the dark tonight with a flashlight, no luck. Where is it exactly?
Where EXACTLY is the fuel filter? (pics appreciated)
Black cylinder with input and output tubing, about 4-5 inches long, 2-3 inches wide.
Should be held in a bracket under the Master Cylinder.
With where you're located, you will likely break the bolt holding it in the bracket so make provisions ahead of time to secure the new one, if it does break.
Should have sprayed liberally with PB Blaster 24 hrs ahead of time for the best chance to avoid breakage.
Might get an Aspire fuel filter bracket, of course you'd need some new fuel line but it would relocate the filter in a much better position.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Yes, under the hood, drivers-side, has a semi translucent reservoir that holds brake fluid has a black lid. Most likely your fluid is black and will need replacing.Originally posted by Basement_Modder View PostMaster cylinder being under the hood, correct?
Also, if I break the bracket, I'll strap it back on with pipe clamps.
Please tell me you own a Haynes or Ford manual for your car.
If not it's a real bargain in helping you learn your way around an engine compartment. It has many pics and illustrations to help ID unknown components.
Zip ties or band clamps will suffice if you break the bolt.
BTW, the bolt is on the backside of the fuel filter a real PITA to get too, so plan on taking some time with it.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Between Kartracer46 and Freshtiva, they must have every part documented in pics!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Mine is zip-tied to the brake master cylinder, underneath it. It is hanging by the horizontal top tube that feeds into the fuel rail. Replacing it is as simple as removing the two hoses that go into it.Originally posted by denguy View PostJust changed the filters on my 2 Festys. I did NOT put the new ones in the original location.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
A million is a lot of fuel filters.Originally posted by Basement_Modder View PostI know how to replace a fuel filter- I've done that a million times- I just couldn't find it.
I just meant that I do not have the filter attached to any bracket or clamps; it's just hanging free.Originally posted by Basement_Modder View PostI know how to replace a fuel filter- I've done that a million times- I just couldn't find it.
Last edited by TominMO; 05-15-2011, 07:42 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
A friend of mine in college, when laundry hadn't been done, and he was out of fresh under attire would say he was "going commando?"Originally posted by TominMO View Post.... it's just hanging free.
Similar concept different context!'93 Blue 5spd 230K(down for clutch and overall maintanence)
