I'm guessing the AC guys didn't properly tension the alt belt if they did indeed mess with it. This would have allowed slipping under load, and eventually it glazed from the extra heat of the belt slipping. Clean the pulleys as mentioned above and probably throw on a new belt as well. Then if its STILL the alt thats looking bad you at least have a brand new belt to put on with the new alt (which I would recommend anyway). If cleaning pulleys and changing belts fixes it, then you didn't buy an alt when yours wasn't bad in the first place
