Well this problem first occured just before I started the front end of the aspire swap. At first it seemed like a dead battery but I ruled that out. Then I checked the spark plugs and there was grey sludge behind just one of the plugs, cleaned that and it appeared to fix it. But now the problem is back and the spark plugs are clean.
Maybe it is the starter? It tries to turn but can't. If I keep on it, it will eventually turn and run fine but it's a real effort. It's always started so easily all it's life so this is new. It's not a fuel problem, and the spark plugs (though they probably don't even play a role at this early stage) are new too. The leads are old. But it sounds like an engine turning issue so does that mean starter/solanoid?
The only other light I can shed is, a number of months back I degreased all over the engine bay and since it was a warm day I hosed it down (something I never usually do)... so it's possible condensation has worked its way in too. Remove the whole distributor perhaps? My flatmate believes it's an electrical grounding issue. I'm confused. Any help appreciated thanks
