I had some work done on my 92 Festi; they had to take the timing belt cover off.
A week after the repair I now now have oil spots on the concrete that were not there before. I can tell by looking at the bottom of that area that it is leaking.
Did he (mechanic) not get the bottom two bolts tight enough? Any suggestions for what I can tell the mechanic?
Actually I'm not much of a mechanic (change oil, plugs etc.). In looking at it I can't see the two bottom bolts. I'm guessing that the belts need taken off along with removing the 4 bolts for the main pulley and then the pulley has to come off to get at them?
Kevin
Kevin
