I have a '90 festiva LX that won't sart. Its been sitting for almost a year. I dropped in a fresh battery and changed the oil. It will crank but that's all. How do I check if its getting spark? I also probably need to add starting fluid, but what else could it be? Its at 250k miles but ran before this.
Help me get it started
You really shouldn't need to use starting fluid, if everything is tuned properly, the engine will start. If it isn't, just fix the problems. Starting fluid is for engines that are old, worn, etc., or cold blooded (s which usually is a cover for being out of tune).
Start with the basics:
Timing belt: broken, or slipped? If not broken, make sure the valve timing is OK.
Distributor issues: getting spark? Plug wires in the proper order? Rotor not put on wrong?
Fuel issues: is fuel getting to the rail? If not, is the fuel filter clogged? Is the pump working? Is the sock clogged? Is the gas fresh enough?
To check for spark, you could pull a plug, reattach the wire, then ground it to the engine while someone else cranks it over.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
You can get an inline spark checker from most parts stores, Harbor Freight has them for a couple bucks.
If your going to pull the plugs, rent a comp tester. It'll tell you alot about your engine's condition.Last edited by Christ; 05-25-2011, 06:21 PM.
I am cranking it with a button. There's no ignition switch, lol. New timing belt on it, too. Just added gas. Filter is clogged, but I have a new one for it I'll be adding asap.1990 White L-Plus 5-speed rust-machine
Scrapped
1991 Blue L 5-speed
daily driver, intermittent project
1993 rustless wonder
A shell, awaiting suspension, brakes, and B6T
Did you "add gas", or just put new gas in, and there was no old gas?
Old gas can be harder to burn, and can exacerbate small problems, making them seem like actual no start issues.
You should check that the fuel pump is providing ample pressure to the rail.
I'll chime in here: if 5 year old gas will run a low compression (8.7:1) engine, then 1 year old gas should easily light off in a higher compression engine (9.4:1). fiero had 5+ y/o gas in it and fired right up with a new battery, same for the 89L that sat for 3+ years.
look for fuel pressure and spark first.Trees aren't kind to me...
I dont always suggest that gas be changed, but after sitting, condensation can contaminate the fuel, especially if there's a any ethanol in it. This, clearly, would be a problem, since you'd have water (possibly water/alcohol) at the pickup of the fuel pump.
The gas in Steve was at least a year old, and aside from smelling like turpentine, it still ran the engine fine.
Originally posted by Basement_Modder View PostI am cranking it with a button.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Originally posted by nitrofarm View PostMaybe you are using the wrong button?Its between +12v on the battery and the positive side of the starter solenoid.
Scrapped
1991 Blue L 5-speed
If there is no ignition switch make sure everything has power before you crank it. Dash bulbs, ecu, sensors.... use a multi-meter, the yellow and black wire that goes to the tps and injectors should have 12v with the "key on".Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
The switch would bypass the clutch safety switch.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
