Well I have been on several forums and on this one as well and I can not seem to find "HOW TO" write ups on modifications/repairs. There are plenty of people saying they have done this swap or that mod with some input to how much nicer it is or what ever but no real THIS is how to do it posts.
Here is the issue, my son had a great little white Festiva, 1988. Had an accident and ruined the front end. We found a replacement 1988 that was running and in decent shape but needed lots of work to be done, but it was running. He stripped the interiors of both cars, swapped them out and overcame some huge obstacles along the way including dashboard swap, steering colum swap, interior/headliner swap, doors, fenders well pretty much every thing. Finally got it put back together and still have some things to do but it was running and drivable. Then he called me the other day saying he had a slight problem ... seems he was hearing a weird noise from the rear and it just didn't seem to be driving very straight. He limped into this mother's and started checking the wheels and noticed that the right rear wheel seemed to be a bit crooked. He noticed the grease cup had been pushed out a bit too and was extremely hot to the touch. Well as luck would have it, he had the right rear wheel bearing seize. When I jacked the car up to investigate, the rear wheel procatically fell off the axle. We pulled the wheel off to see if we could get the drum off but it just did not want to come off. Finally was able to get the drum off along with alot of little pieces mixed in the grease. Seems the outer bearing has welded itself to the spindle so it's a loss.
Was able to remove the spindle but there is literally no way to salvage this thing with the limited tools I have. Next solution was to find all the parts need to replace the wheel bearings. Got all the parts form my local auto parts store to include both inner and outer bearings, seal, and wheel nut. Got enough for both sides. Came to just under $80. Now needed a spindle. Went out to our local wrecking yard and the only 1988/89 had both of the spindles stripped already. We found an Aspire with both hubs complete. We removed them thinking maybe they will fit. But after trying to fit them ot the 89 in the yard it was noted that the mounting studs match the lower holes but are too wide for the upper. I contemplated drilling out the holes larger to accept the Aspire hubs and spindles but investigation shows that the wheels are different spacing bewteen the Festiva and Aspire (yea) so that means the wheels and tires will not work on these hubs. I was also concerned about mounting the spindle/hub to the Festiva suspension after drilling the holes out in that I don't know if the attaching nuts would clear the inside of the suspension so they could be tightened. So even if they would mount up we still have the issue of the wheels.
The only other possible candiate was a 1991 Festiva which has been a donor car of sorts with doors, fender, interior trim, seats and hatch. The problem manifested itself when I attempted to remove the hubs and spindles. The spindle mounting studs are bigger as wellas the nuts that hold them. They upgraded them from a 14mm stud/nut to a 17mm stud/nut so no way it will fit in the 88 suspension.
So here are some questions. From what I can find, and what the wrecking yard guys tell me is that the rear suspensions between the Aspire and Festiva will not be a direct swap as the rear suspensiton mounts are not the same size or spacing. They mentioned that the Festiva suspensions are compatible between 88-93. does nayone know this for certain? Will it directly bolt up to the 88 frame? Has anyone done this? I will have to most likely get different bearingsas well but they can be traded for what is needed. I know it would just be simplier to just find another spindle but I can't find one.
I know this may seem like an extreme but I wnated to upgrade the spindles to a cotter pin type lock of the nut to the spindle, much cheaper to replace a cotter pin then the spindle nut. Trying to swap the Aspire hubs won't work as the stud spacing is different then the Festiva and requires getting new wheels, remounting tires rebalancing and all I can see is $$$ which neither my son nor I have right now. Locating a replacement spindle for his 88/89 has not been very sucessful as there just are not any in the wrecking yards.
Something to remember on these forums is that most people may know what they can or can't do and sometimes assume everyone else who has one of these vehicles knows how or understands what is needed to do these same things. This is not always the case. There are problems that are encountered or issues that are not understood by the novice or new owner. Even with mechnical abilities and understanding, alot of us don't have ready access to welding, cutting, special tools etc and getting information on how to do some of these is difficult to try to sort through all the posts trying to find what you really are looking for. Direct bolt up prjects are what is needed for some repairs and these forums are a treasure trove of information because of the people on here. So any help, suggestions recommendations and or directions of how to do it, links showing telling how to do it that have been posted would be huge. I have tried the search engine but I just can not find the information I need to quickly get his little car back on the road. Thanks
