Oil Seal
  • Oil Seal
    Any secrets on getting the drive axel oil seal out?
    1988 festiva manuel tran
    I always use a seal puller but a large flat head screw driver should pop it out too. Pretty much anything you can get behind the metal housing of the seal and pry it out.
    WWZD
    Zulu Ministries
      it just keeps comming apart. I guess i will just have to work at it. Its a pain.
        If the metal seal casing is tearing, try using something a little wider to pry with. Maybe a small crowbar or something with a little more surface area so it doesn't try to rip through the metal lip. I've had ones that have been in for years that try to rip like that when you remove them... it's pretty annoying.
        WWZD
        Zulu Ministries
