pulled the hose off my air filter box the other day when i was removing my valve cover and oil came running out... i expect a lil oil in there but there was quite a bit more than i was expecting!
its a 91 FI... whats the most likely cause? bad rings? is it something i should worry about? i'd say there was at least a half a cup or so that came out... as far as i can tell my engine doesn't really use up any oil between changes, but this has probobly been building up for the past year and a half since i changed my filter...
which brings me to my next question: if i have to replace the air filter what kind of bennifits would i get from upgrading to a cone air filiter? i have a cherry bomb (free flow) muffler on, so am i correct in understanding it would help if the engine could breath easier on both ends?
thanks
thanks
