aspire steering rack
  • aspire steering rack
    Was wondering if the aspire rack will fit the festiva with out swapping the inner tie rods i know the outer ones are different. My car needs a rack and the yard has a festiva but the motor is in it and it hard to get to all the bolts and the aspire they have has no motor so a bit easier to get to.
    Rack will work yes ,but inner tyrods are longer they have to be switched ! Will only work on a fuel inj car . The carb inners are different as well on the thread end .
    New build on the way .
      Good to know!
      Karl
        Thank you
        The inners don't make a big difference to me then because this car is a complete shell. So this is so i can push it around so can fix it.
