Ok so I've finally been working at getting my heat gauge working with my KL and at first I wired up the KL sensor direct to my cluster by running my own wire to keep it hidden to go with my wire tuck and that didn't work
So I assumed it may have been a difference in the KL sensor to my gtx gauges so I knowing that my heat gauge worked with my B6T using a stock festiva sensor, I figured get a stock festiva sensor, put it on my KL and it should work
Well no go, the festiva sensor was a direct swap though, so I figured maybe my wiring was wrong (even though I did a continuity test to check it) so I ran the stock Festiva temp gauge wire and ran it to the sensor, and it still won't work
So I'm getting a bit stumped on how to get it to work, how does the heat gauge work? Could I possibly be missing a ground somewhere? Does the heat gauge even need a ground since it's a single wire gauge?
I'm just looking for ideas to try and get my gauge to work so any tips are greatly appreciated
