Stock '93 L, fires up just fine, and moves in reverse just fine, but then taking off it lurches/surges. After that it runs out fine, just like always, and responds when I step down on it (and so I don't think the fuel filter or injectors are at issue), After it warms up the problem is greatly diminished. The brakes are not sticking, either. Thoughts?
Lurching in 1st gear, esp when cold
timing curve or possibly clog in the vac line to the fuel pressure regulator.
i'd check timing first, then go from there.Trees aren't kind to me...
