Hi Everyone,
I have been going through site to see if anyone has had or is having the same problem, but i have yet to find anything. I hope that someone here can help me figure out what it is because i really love my Festy and do not want to get rid of it, but we will be moving next month and if i can't get it going by then it will be left behind
Anyways here is the issues i am having:
First off, The story behind it.
I was driving my son to work,got about 4 blocks when out of the blue i hear this pop sound and a small flash of light that seemed to originate under dash far left side and everything went dead like it had no battery.. It would not crank,no lights,NOTHING AT ALL!!!
. So there i am side of road hood up, scratching my head wondering what had gone wrong. Started checking engine area and found a fusible link wire burned in half.Well that should be an easy fix so i got a section of close gauge wire and put it on and turned on key it had power again cool.Turned it over and it would only crank and would not fire up.I am now thinking this is not going to be a good day,about that time i look up and yep police car pulling up. At first i was thinking well it just got worse but to my surprise he was in a good mood and actually ended up giving my boy a ride to work
. So i walked back home and got my wife and younger son to help push it back home.
Since then tested for spark (has good spark) fires up with ether sprayed into air induct.
The fuel pressure, pre filter is @ 35 psi while cranking because it does nothing with just key on???
Checked for power to injectors with with lite tester and meter (no power with key on, or cranking)
Checked connections back to where it goes behind driver fender (all good)
Looked under dash for any signs of burnt wire or loose connections (looked ok)
So no power to injectors is where i am currently at. What powers them? ECM, camshaft positioning sensor?? how do you test?
I am not good at fixing electrical issues and can't afford to put in parts that are not needed. The moving expense is is bad enough lol. So any help would be greatly appreciated.
Sorry for such a long boring post.......
Thanks in advance
John
Thanks in advance
John
