I just finished my engine swap but I do not remember the correct placement of the fuel lines. I had marked them with a paint marker, but fuel ended up leaking out of one of the lines and caused it to disappear. Im guessing that the sending line is the one that comes out of the black canister that I assume is the fuel filter.
Proper fuel line connection
Yes, The line coming from the fuel filter is the one coming from the tank
The other one is the return line
correct. And that one is connected to the portion of the rail that does NOT have the regulator. The return line gets connected to the regulator.Jim DeAngelis
