When I hold the top of the tire and shake there is a bit of play. A search of the site suggests worn bearings but they are brand new. Could it be something else?
I put new bearings in two hub-and-knuckle assemblies, one is the original and the other is from an auto wrecker. Both have this bit of play in the driver's side wheel. They are okay at first but after a test drive around the block there it is. Actually it's three times because I thought the first set may have been out of spec and exchanged them for a different brand. I'm getting real good at replacing bearings but really just want to be able to drive the car. I assume driving with a bit of play in the wheel is not good so don't.
Thanks for any insight.
