Is it because I'm doing it by myself? I've got the driver's CV shaft removed, 3 of the 4 crossmember bolts removed so I can slide the trans back. At this point I'm figuring on putting the jack under there and undoing the 4th bolt so I can slide it back even more. I had the input inside the pressure plate fingers, but I couldn't get the input into the pilot bearing, and yes, its still centered.
I put the front mount on so I knew about where I had to be, maybe take it back off.
I've also got to replace the outer boot on the shaft and I'm having a hard time getting the CV off the end, any secrets there?
Just remember there are 10 not nine bolts holding the tranny to the motor.
