Howdy here is the run down :1990 GL 5 speed. Right and left rear turn signals work fine. However in front only the lower right works. No power to upper right and no power to lower left. Strange thing is I'm getting around 2 volts to the left side upper. I used the hazard switch and the turn signal switch and got the same results. I am at a loss.
Should I start tearing all the wires out and check for shorts?
