Hi all,
I just picked up an '88 Festiva L. Clean shell but it won't start. It turns over and if you spray starting fluid into it it will run for a bit then dies. It sat for a while and I am not the first person to try and get it going.
The fuel pump didn't seem to be pumping anything... It appears brand new. The spacer is in place. Ichecked the tank, It was empty. I put in a gallon or two but it still doesnt seem to want to pump. How long do these take to prime? I can't get my vaccuum pump to build any vaccuum on either the fuel line or return either. I'm dropping it now to check for leaks.
I took the carburetor in to get it looked at as well. They told me that whatever lets the fuel in for idling is completely blocked. I've worked on lots of cars, but they were all FI. I am new to carburetors.
I found a fellow on here that will rebuild for $150 and will probably take him up on that once I am positive I have fuel getting to it.
Initial questions;
1. Is there anything I am missing here? These cars seem simple but the vaccuum diagram looks like a bunch of snakes having an orgy in a bowl of spaghetti.
2. Is the top of the tank accessible from under the seat to remove lines/etc.? Everything is loose from below but it seems to be caught on something.
3. If I can't get this POS running, who wants to come buy it?
Initial questions;
