I got the motor back into the festiva, but need to know the location of a wire near the starter on a 1990 with 5spd. Where the battery cable exits the harness to attach to starter there is a thin black wire with a large round end to attach a bolt to. Does anyone know where this goes, looks too small to be a ground.
need help with starter wiring
Because my post was at 1AM in the garage I probably wasn't very clear on what I'm looking for.
Near the starter there are 3 wires. One thin black wire that clips to a tab on the starter. One thick wire from the NEG battery terminal and another thin black wire with a large eyelet on the end of it. Not thinking I connected this thin black wire with large eyelet to the other terminal on the starter and when I turned the key on it fried the wire. I've traced the wire back up to behind the battery, but am unsure what it does. Does anyone have any input?Chad
1990 Tiva L - Yellow
1995 Metro - SOLD...
2002 F150 FX4 - Black
1966 Galaxie 500XL - Black
I think that grounds in the same place as your neg battery cable. Wait till someone else responds though.sigpic
Probably a Ground
I hooked this wire up to a ground bolt on the transmission and the car will crank ok, so I think that is all it was unless someone else has any input?
Now onto why the car won't start.Chad
Check your fuseable links.Originally posted by chadzeilenga View PostI hooked this wire up to a ground bolt on the transmission and the car will crank ok, so I think that is all it was unless someone else has any input?
Now onto why the car won't start.sigpic
