I wrapped up the install of the rebuilt engine in my 90 Festiva. Everything is in it's place other than the exhaust manifold. I have tried to start the car and cannot get it running, it will crank and crank and try to start but never fire up. Here is an overview of what I have checked.
- Fuel Pump is pumping with key on. I left the hose to the injectors off and on the floor. With key on and engine turning, a steady stream of fuel came out.
- I pulled the #1 plug wire and there is a spark when the engine is cranking.
- There is a light amount of blue combustion flame coming out of the #4 exhaust when cranking.
- When I hold my hand over exhaust ports 1-3 during cranking I can feel a suction, is this right?
Harbor Freight, they are cheap.
