arghhh.... ecu... i think
  • arghhh.... ecu... i think
    ...91 l fuel pump brand new but not building pressure... r.j. had a spare airflowmeter.. didnt work... the pump is getting power but no ground
    and it was sudden
    91L 5 sp, 175k,a/c ,KYB gr2,Fms Lowering springs ,13" konig's ,09 tiburon seats, 7" Pyle in.dash,kicker ds400 all around,Kicker 400.2 powering 2 Kicker cvr 10", 30k hid's, hopeful to find a xr2 to swap b6t from....
    2010 mazdaspeed3 stock... for now
    ok i have someone up here with the same issue.
    here's what you need to inspect: check the connections and pins at the short harness extention between the main harness and tank (the one in the plate), then also check the pins at the pump mount (you can disconnect them from the back side). i found one wire (it happenend to be the hot wire (pun intended)) that had melted through the pin bracket and caused a break in continuity to the pump.
