hay guys, i'm tring to optimise my fuel milage and i want to set my iginition timeing on "Little red" It uses a vacuum advance distribution and i had replace the distributor a while back (old one was bad), so i just set the new one in the middle of the e-longated holes, but i know its not probibly in the right spot, i looked online and it showes a yellow mark on the pulley for use with the timing gun, my pulley has two parts, looks like an ac unit could have been run off the outer (nothing currently run off it) and the inner is the alt belt and such, there are no marks on either to indicate the timing, is there some why to make your own marks or something?
Thanks
Thanks
